Two-in-One Network and Power Supply
Compatible with ROCK 3A / ROCK 3B / ROCK 3C / ROCK 4C+ / ROCK 5A / ROCK 5B
Compliant with IEEE 802.3at Standards
Significantly streamlines the complexity of network cabling and power management.
IEEE 802.3at
PoE Standard
Up to 25W
Safety and Reliability
Enhanced Heat Dissipation Efficiency
The Radxa 25W PoE+ HAT comes equipped with a programmable cooling fan and temperature sensor
Delivering an airflow of 1.45 CFM to help you achieve exceptional processor cooling performance.
Quick and Easy Installation
- Steps 01
Package List
- ・ 1x Radxa 25W PoE+ HAT with cooling fan
- ・ 4x M2.5 x 5 mm Copper Pillars
- ・ 4x M2.5 x 9 mm Copper Pillars
- ・ 4x M2.5 x 4 mm Copper Pillars
- Steps 02
AccessPass four M2.5 x 4 Copper Pillars through the four positioning holes of Radxa SBCs, and individually secure them to M2.5 x 9 Copper Pillars to ensure a sturdy fixation.
- Steps 03
Align the Radxa 25W PoE+ HAT with the PoE interface and the 40-Pin interface, and insert it carefully, ensuring that it passes through the 4 x M2.5 x 9 Copper Pillars.
- Steps 04
On top of the Radxa 25W PoE+ HAT, align the four M2.5 x 4 Copper Pillars with the four M2.5 x 9 Copper Pillars, then secure them by rotating them into place.
Radxa 25W PoE+ HAT
Global
25W PoE+ HAT Works with
Radxa CM3S IO Board
an Application Board for Radxa CM3S(mEdge-RK3566)
Radxa CM3 IO Board
Radxa CM5 IO Board
an Application Board for Radxa CM5
Radxa ROCK 3C
Radxa ROCK 3A
A Credit Card Sized SBC with Rich Interfaces
Radxa ROCK 3B
An Pico-ITX form factor SBC with Multifunctional Interface
Radxa ROCK 4C+
A High Compatibility SBC with Dual Display and 4K
Radxa ROCK 5B
Radxa ROCK 5A
Radxa ROCK 5C
