Radxa ZERO 3E PoE HAT
Designed for Radxa ZERO 3E
Usage Steps
- 1. Radxa ZERO 3E
- 2. Radxa ZERO 3E PoE HAT
- 3. Copper Post with Heat Shrink Tube
- 4. CM2.5×4×4 Crews
- Steps 01
First, remove four CM2.5×4×4 screws from the Radxa ZERO 3E PoE HAT.
- Steps 02
Then, align the Radxa ZERO 3E PoE HAT with the 40-Pin GPIO Header of Radxa ZERO and then install it.
- Steps 03
Then, from the back of Radxa ZERO, use four CM2.5×4×4 screws to fix Radxa ZERO and Radxa ZERO 3E PoE HAT.
- Steps 04
Finally, plug the Ethernet cable into the port (requires PoE support from the switch/router at the other end of the cable).
Note:The implementation of PoE functionality on Radxa ZERO 3E involves screws and copper pillars,
which need to be securely fastened. Without installing the copper pillars and screws, the PoE
functionality cannot be utilized.
ZERO 3E PoE HAT Works with
- Radxa ZERO 3E
A Light, Compact and Tiny SBC
