25W PoE+ HAT 12V/2.1A
Designed for Radxa X4, X5, and Q6A, supports 12V/2.1A output
Distinguishing Features of Two Versions
Radxa 25W PoE+ HAT 12V/2.1A powers Radxa X4 via 2-Pin Power Output Header.
Radxa 25W PoE+ HAT 12V/2.1A Powers Radxa X4 via 2-Pin Power Output Interface.Radxa 25W PoE+ HAT 12V/2.1A Powers Radxa X4 via 2-Pin Power Output Interface.
Two-in-One Network and Power Supply
Power connector schematic
cable
Compliant with IEEE 802.3at Standards
Significantly streamlines the complexity of network cabling and power management.
IEEE 802.3at
PoE Standard
Up to 25W
Safety and Reliability
Enhanced Heat Dissipation Efficiency
The Radxa 25W PoE HAT for X4 comes equipped with a programmable cooling fan and temperature sensor
Delivering an impressive airflow of 1.45 CFM to help you achieve exceptional processor cooling performance.
Quick and Easy Installation
  • Steps 01
    Package List
    Package List
    • ・ 1x Radxa 25W PoE+ HAT 12V/2.1A
    • ・ 4x M2.5 * 5 Copper Pillars
    • ・ 4x M2.5 * 9 + 6 Copper Pillars
    • ・ 4x M2.5 * 4 + 6 Copper Pillars
  • Steps 02
    Schematic diagram of the second step
    Secure it from the back of the Radxa X4 using four M2.5x4+6 copper pillars. Ensure that each copper pillars is precisely aligned with the mounting holes and gently screw them in until the copper pillars are firmly in place.
25W PoE+ HAT 12V/2.1A Works with
