Active Air Cooling Heatsink
Features aluminum cooling fins and active air cooling for efficient heat dissipation, improving stability under sustained high workloads.
Purpose-Built for AICore AX-M1 / DX-M1
The full-coverage heatsink design delivers efficient cooling, while support for the onboard fan connector makes installation quick and easy.
Dedicated Fan Connector
The heatsink fan is only supported on AICore AX-M1 / DX-M1 versions with an onboard fan connector.
Easy to Install
Package List
- 1x Heatsink 2375B
- 2x Thermal pads
- 2x CM2 Screws
First, as shown, place the Radxa AICore AX-M1 into the heatsink bottom cover and make sure it is properly aligned.
Next, as shown, align the fan cable connector vertically with the fan connector on the AX-M1. Confirm the orientation, then gently press it down until securely connected.
Then, apply the thermal pad to the main heat-generating area of the AX-M1, ensuring proper coverage and contact with the primary heat-generating components.
Finally, align the heatsink with the bottom cover, install it in place, and secure it using the supplied screws.
