Heatsink 6530B
Heatsink Specialized for Radxa Cubie A7Z
Heatsink 6530B
High-Efficiency Cooling Design
Aluminum alloy material with excellent thermal conductivity, 3D fin structure effectively increases heat
dissipation area
Heatsink 6530B
Smart PWM Speed Control
Real-time fan speed adjustment, Enhances airflow efficiency while balancing cooling performance
and noise
Heatsink 6530B
Easy to Install
    • ・ 1x Heatsink
    • ・ 2x Thermal pads(16 * 16 * 1.2 mm)
    • ・ 4x Screws (CM2 * 4 * 4 mm)
    Package List
  • Apply the thermal pad onto the SoC of the board
    Steps 1
  • Place the heatsink onto the board
    Steps 2
  • Secure the heatsink with 4 screws
    Steps 3
  • Connect the fan cable to the board fan header
    Steps 4
Heatsink 6530B Works with
