Seamlessly Matched and Perfectly Adapted to ROCK 5B
Maintain the Stable Operation of ROCK 5B with High Performance
Metal Case specially sets aluminum heat conduction columns for SoC to achieve rapid cooling, keep the device stable and prolong the service life.
The aluminum cooling fin design increases the heat dissipation area through the fin design, and quickly conducts the heat generated by the SoC to the surface of the heat dissipation box.
The unique design of the bottom cover sets the ROCK 5B Metal Case apart and provides efficient thermal protection for your SSD. The thermal capacity of the bottom cover always ensures that your SSD maintains excellent performance.
Robust Structure to Avoid External Mechanical Damage
1x Metal Case
1x Side Cover (Ethernet Side)
1x Side Cover (Micro SD Card Slot Side)
1x Base Plate
4x M2x8 Screws
1x Thermally Conductive Paste
Apply a pea-sized amount of thermal paste to the SoC location on the ROCK 5B. Then, use a brush to spread it evenly.
Insert the side cover with Ethernet and HDMI ports into the metal case enclosure.
Align the side of the ROCK 5B with the Ethernet port to the side of the heat sink box that has the Ethernet port, ensuring that the SoC is aligned with the heat sink box's heat column.
Insert the side with the TF Card Slot into the heat sink box to ensure a secure connection.
After installing the bottom plate, secure it in place using M2X8 screws.
Antenna installation, as shown in Figure.
Apply Thermally Conductive Silicone for the SSD, ensuring a thickness of at least 3mm.
