Heatsink 5540B
Specialized for Radxa Compute Module
Heatsink 5540B
Compact Design. Active Cooling
Compact active cooling solutions for SoMs
Heatsink 5540B with active cooling airflow
Flexible Compatibility. Easy Installation
Compatible with multiple SoMs, with mounting screws and a thermal pad included for easy installation
Heatsink installed on a carrier board; compatible with Radxa CM3, CM4 and CM5
Compact Size. Efficient Air Cooling
Active air cooling with aluminum alloy fins in a compact 55 × 40 mm footprint for easy system integration
Aluminum alloy fins; 55 × 40 × 14.5 mm; fan speed up to 7000 RPM ±10%
Version Comparison
ModelRadxa Heatsink 5540B V1.0Radxa Heatsink 5540B V2.0
PictureV1.0: hydraulic bearing, 11.5 mm heightV2.0: dual ball bearings, 14.5 mm height
Bearing TypeHydraulic BearingDual Ball Bearings
Height11.5 mm14.5 mm
Dimensions55 × 40 × 11.5 mm55 × 40 × 14.5 mm
Heatsink 5540B Works with
